The original plumber left this clean out sticking up. Shouldn't be like that. So I'm guessing I should cut it flat with the concrete, then fill it in or cap it off somehow?
The rest of the pipe is sticking out from under the slab. What size and type should I use to make the clean out there?
For the well, where is the pipe that the house water should come from? Is it one of those valves?
