umcgirl said:
...semi gloss enamel interior latex - valspar. We primed with Klitz. My husband is frustrated with the paint brush lines. Help, before we add another coat.
After letting it dry and cure for a bit, sand it smooth (sand out any brush marks you can)
Then apply a premium quality waterborne* enamel, such as Ben Moore's Waterborne* Impervo, or Sherwin Williams Waterborne* ProClassic, using a premium quality brush and proper technique (not too thick and don't over brush)
You may see a few brush lines, but not nearly what you do now
And a brush is not a brush...so to speak
Use a good quality Purdy, Corona, or Wooster brush
Exactly which will depend on your particular technique and/or preference and/or product, but you may not have painted enough to figure that out....so anything in those lines should be OK for now
Although additives (such as Floetrol) should only be added if needed due to atmospheric conditions, they can add some "forgiveness" to the WB enamels for sometimes painters
But they are a tool...not a crutch
I'd suggest the premium WB enamels straight up if at all possible
Technique is something you have to do, be evaluated on, and work on
It can't be learned over the interweb, or even by doing a few paint projects
But, using proper quality tools and products, if it's still unacceptable, it's probably technique
.... or you want no brush lines at all...not possible w/o spraying (and proper prep, products, and technique)
In your case, it sounds as if you use proper prep (sanding), tools (premium), and product (premium), even with brushing, it will be at least acceptable, if not "whoo hoo! Look at that!"
*The word "enamel" can mean a cheap paint, but it's technically an enamel
Often cheap paints with sheen are technically (latex) enamels, but are miles away in quality from "waterborne" enamels (WB enamels are the water-based version of the old fashioned oil enamels)
Yes, it's splitting hairs name-wise...but there is a big difference
Many premium lines (Impervo, Pro Classic) have both WB and alkyd (oil) versions
Be sure to get the correct type
