Okay, all the big notches are gone and I was able to use the wall blocking as deadmen for the siding girts.Yes, a lot of the vertical support is regained with good, snug-fitting, cross-members. But when the inertial moments are stressed, as they would be from side loading wind factors, at least one direction proves to be weaker than the un-notched piece would have been.
I happen to love Timber Framing, and I think (although extra work) mortising in the heads of angle braces and cross-members would be sharp.
I've put Simpson LUC26Z concealed flange hangers in for outer 2x8 joists and beams (it seems to be the only concealed flange hanger they make for 2x), but I don't know if these will be strong enough to use on the front and rear beams - I might have to attach actual slabs of lumber to act as deadmen there (blech).
