Hi all,
Looking for some advice.. we had a Sams club pergola on our 4" thick stamped concrete patio, and hadn't secured it quite yet to the patio (it comes with 4 resin "feet" that were supposed to be secured with four 1/4" tapcons each).
We had a freak severe straight line wind come through (70-ish mph) which pushed it/slid it just off the edge of the patio and it toppled over.. so I'm rebuilding it... and securing it this time.
This was not a normal wind.. it took out trees and power lines in my neighborhood, but the resin square feet this pergola comes with are only secured to the 5.5" cedar posts through their 1 inch cedar facing (inside the post is a 4x4 for support in sections, to make the overall weight and cost less I'm sure)
Instead, I purchased some Ozco post brackets so I can secure the side plates with screws into the meaty 4x4 centers of the posts, rather than just the facing...
What I'm wondering about, is if I should secure the post bases to the patio using one 1/2" or 5/8" tapcon/titen bolt in the center of the standoff plate, or use four 1/4" tapcons to secure the standoff to the patio/slab.
The Patio is 4" thick concrete with mesh. I am not going to cut it out and built piers or footings. I'm going to secure it with the Ozco base plates. With the slab being only 4" thick, most of the larger tapcons/titen bolts that are 1/2-5/8" diameter, are too long and I would be drilling through all of the concrete, and wondering if just securing with four 1/4" tapcons in each base would be just as effective given the thickness of the slab..
Thoughts? The Ozco OWT bases allow for either method of securing to the patio... one large bolt or four 1/4" screws..
Any advice on which method is preferred for a 4" slab would be great... Pergola has corner bracing so I'm more concerned with keeping wind from sliding it along my patio or uplift than I am with it scissoring down in an wind..
Thanks all!
Thanks all!
