Hello all,
I'm looking for some advice on securing 6x6 pergola posts to the lower cement block wall shown in the attached picture. The pergola will run the length of the house and the top lattice beams will secure to a beam attached to the cement blocks on the house just below the siding.
The posts will also have 45 degree wood supports to strengthen horizontal movement.
My concern is the strength of that wall and whether it is enough to support a pergola, and if by securing it to the wall there would be a potential to cause damage and have it collapse.
What you don't see is that on the other side of the wall there's dirt and grass that will ultimately be replaced by stone pavers. The top of the wall is level with the bottom of the house.
