1 - 10 of 10 Posts
Hi all,
Just a quick question, I am looking on advice on how to secure the wires into, and out of my outlet boxes (I think code is that they must be secured within 12" of enter/exit of the gang box). I think this is traditionally done with the staples but I have superior walls in my basement and I'm not sure what would be the best way to secure these wires being that the studs are foam wrapped.
I'm sure you all are familiar with superior walls but I attached a picture just in case.
Use long screws that will penetrate the foam and get into the studs. You can get a collar that encircles the wire and that has a tab with hole for one screw to hold it onto the stud.
How are you going to anchor the outlet boxes?
· Licensed Electrical Cont.
You will need romex or pushin connector to secure wire or wires to the boxes.
Totally agree. They way you have it is non-compliant and not safe.
As far as securing goes, use TapCons, or other concrete screws, to fasten tie-wraps with a mounting lug.
Reactions: tweak
· Super Moderator
To make it easier to comply with fastening the cable within the 12" I would use the top or bottom knockouts, not the side one like shown.
1 - 10 of 10 Posts
