1 - 8 of 8 Posts
This is my first post, so hopefully I am following the proper etiquette. I am trying to install an automatic 3-way timer switch (Honeywell PLS750C) and had a question about what to do with an unused ground wire.
The area that I am working in is a 2 gang box with two separate 3-way switches (controlling different lights). Each switch is currently connected to two travellers, a common, and a ground wire. I want to replace one of the switches with the automatic timer. The timer is designed to be connected to the two travellers, the common wire, and a neutral wire (unused in the existing 3-way switch, but it exists tucked away). The timer is not meant to be connected to the ground wire, which currently is connected to the existing switch. What do I do with this unused ground wire? Is it safe to just leave it in the box unconnected to anything?
Thanks.
:eek:
Lots of info to sift thru, which I didn't (at least not completely), but yes you can leave a ground unconnected if it's not needed.
EDIT: make sure to twist it to any other grounds in the box if there are any for continuity of ground.
Thanks. Sorry if it was too wordy. Basically I have an unused ground wire and didn't know what exactly to do with it. Just to make sure, I can connect the unused ground to the other ground in the box (which is being used as part of a 3-way switch)?
If I am reading your post correctly, what you call a common is actually a point wire, the 3rd wire on a 3-way on the identified screw, 2-travelers and a point wire. (AS FAR AS I KNOW this is not a local term, but I have been wrong before)
I mention this as many DIY'er ofter refer to the neutral as a common.
Not a major issue by simplifies discussions if we all use similar terms.
It depends on context. The white neutral wire is often called the common. But since the OP is talking about 3 way switches, and specifically said the white neutral wires were tucked away behind, the common terminal of a 3-way switch is a hot wire. It's the hot lead the 2 switches have in common. So in that context he's correct, there are 2 travelers and a common. The common is the black screw typically. I've never heard the term point wire.
http://waterheatertimer.org/images/3-way-circuit-500.jpg
I too have not heard that term associated with a 3-way. I know that if you look on a switch though that it is labeled "com" and it is the common terminal to the other 2 terminals on the switch.
Not to be contrary but I think the OP got this one right.
1 - 8 of 8 Posts
