Hi, I am replacing my old thermostat with a Nest smart thermostat. The Nest requires a 24V input. I removed the old thermostat and luckily there are two unused wires that are taped up in the junction box, which trace back to a 24VAC transformer in the attic. So it appears I have the wiring already in place for my new thermostat.
Being curious, I tested the voltage to ground coming from each transformer wire by touching one probe of my multimeter to a wire, and the other probe of my multimeter to ground. The multimeter reads a voltage of about 12V coming from each wire individually. However, when I measure the voltage across both wires (by touching one probe of my multimeter to one wire, and the other probe of my multimeter to the second wire) I get a reading of 24V.
What is going on here? I have done some reading and think it may have something to do with the transformer output not being grounded (instead I think it is floating). Does that sound correct?
Thank you,
- Scott
Thank you,
- Scott
