This is my second attempt at a faux stone project, or any kind of stone project for that matter. The first was a sign I built and used "cultured stone" brand for the bases. This next one is some "Coronado Stone" I'm putting on the fireplace which we're finally getting around to doing after living in our house for 13 years. I have already laid stone on the hearth, using polymer-modified thinset, and plan to lay the wall using polymer-modified mortar. Does it look like I have the stone arranged right? The ones sticking up are the corner/returns which have not been cut off yet. Should I use larger stones directly over the top edge of the fireplace insert? I have installed a piece of black-painted 1/4x4 flat bar attached to the header above it and sticking out about 3/4'' or so out from the scratch coat as sort of a heat-sink barrier. I'm just wondering if it will look right. Thanks :smile:
