1 - 8 of 8 Posts
System is as follows: Well pump, holding tank, pressure pump, house.
At the pressure pump, I have it set up where the feed is coming from a lower bulkhead on the tank instead of an upper, so water flows down into the pump instead of the pump lifting the water (what these shallow well pumps are designed to do).
Normally you'd use a foot valve, but that wouldn't work with this setup.
So do I just stick a standard half pound spring check valve between the tank and the pressure pump? Right now the pressure pump won't maintain pressure, because it back feeds into the tank every time it clicks off.
That's what I've got on the top of the pump, but I thought they worked better sitting upright, whereas the plastic spring loaded would be able to sit upside down/sideways or whatever direction it pleased. Will the brass flapper style work in any direction?
It will not work in any direction. Just my preference. I like the cap for priming if needed.
The inline spring loaded ones are fine as well.
That's what I thought. Yeah, I like them better as well. That's what I put on the top of the pump.
This one will be sitting sideways, so I need the spring.
· Super Moderator
While your at it I think I would put a shut off at the bottom of the tank. Then you can work on the pump without draining the tank. That check valve can sit sideways. It does not need to be vertical. The flapper does not sit vertical. There is a bit of an angle so that is seals when sitting flat.
I think what I would do is an elbow, a shutoff and then the check valve. Keeps the connection from sticking out too far from the tank and being susceptible to being knocked off. The elbow can point sideways or straight up.
Discussion Starter · #8 ·
Ok, a 90 similar to the top bulkhead. I've got another brass check sitting around here somewhere, I'll stick it on today. Tomorrow I'll go grab a shut off valve, because you make a good point there.
1 - 8 of 8 Posts
