The garage door opener was here when I moved in. I know nothing about the age of it, though I am sure it has seen better days.
It's a Sears Crafstman Plus 1/3hp.
Model# 139.53609
This morning I left to go to work. Opened the garage door, and it went up fine. I backed out and hit the button to close the garage door. I heard a loud "screech" sound as it went down. It closed. Being in my truck, I couldn't tell where the screech came from.
I came home from work, and opened the garage. I heard the Screech again, and the door opened. I walked in, and hit the button to try to listen for where the screech was coming from. It screeched loudly, the door went down about a foot, then completely stopped. I heard two "hummmmm" sounds, one right after the other coming from the garage door motor. (Hummmmm! Hummmmm!)
I assume that the first "hum" was from the motor trying to go one direction. The second "hum" was the motor reversing direction, with the motor locked up both times.
Next, I needed to determine if the door was getting hung up in the tracks, or if this was actually motor related. I pulled the release, and released the door from the track.
I hit the button again. First, the loud screech, then two "hummmm" sounds back to back.
I then unplugged the power source and removed the cover. (I know the capacitor still holds a charge). I hit the button again, and could easily pinpoint where the screech sound was coming from.
Here's a pic with the cover removed. The area circled is where the screech is coming from.
Here's a closer look at that piece.
I can see slack in between the snap ring and washers? The tips of the black plastic end appear to have been rubbing on something. The washers look like they are coming in contact with the yellow piece that has the plug going to it. I believe that they are, and this is what is causing the motor to lock up.
Curious to see if they were loose, I poked at them with a screw driver. Everything slid up/down the shaft a bit.
I searched the Sears parts site for the opener.
http://www.searspartsdirect.com/par...ts/Model-13953609/0247/0718000/00015233/00001
It looks like the black plastic piece is called the Interupter Cup Assembly (Part #19), and is no longer available.
Part #15 appears to be the same thing, but is called the Sensor Assembly.
Part #18 is the bearing assembly. Also, no longer available.
This is what I thought were washers and snap rings.
Am I right to say that the bearing went bad, came apart, and is causing the motor to lock up?
Should I try to find a new bearing, or just replace the garage door opener all together?
(If I replace it with a new one, I would be getting two garage door openers. I have a 2 car garage, with separate doors for each side, but only one side has the opener.)
If I replace it, are there any suggestions on a reliably known brand or model to get?
