#1, That shed should be at least 6" above grade to prevent the damage in the first place.
Ayuh,...... Raise, or move the shed,.......Hi DIYers!
I am in the process of building a shed where rain water drains out to the street. At worse case there maybe a few inches of water as it drains. At heavy rain the water would likely touch the pressure wood treated foundation I would build.
Do you recommendation some type of sealant to help protect from rot?
THX!
Ayuh,..... The thing is, Don't block the water's flow,.....Thx Guys! Moving it is not a option, I will have to put a concrete base under the wood base.
