What's the accepted practice for drywalling around a plumbing penetration, when the drywall is meant to have a fire resistant effect?
In this case it's a 1940's boiler room partially covered in sheetrock, but later compromised to run new copper freshwater (not steam) pipes.
I'm thinking of cutting a U-Shaped patch and slipping it over the pipe, filling the U-shaped gap with another piece, then fire caulk. In the boiler room it does not have to be pretty. Sticky fiberglass tape and mud would complete the job.
Don't WANNA do it myself
They make fire resistant spray foam, that would probably be your fastest and easiest.
After the foam sets trim it down and put a plastic escutcheon on it
OP here:
I ended up patching drywall in, then using foam (using a foam gun, not those ridiculous cans that clog after 2 hours). There's no way to test it of course :).
