I am installing new ductwork in my home, currently there is no A/C and the heat is hot water radiators. I am using mastic and UL rated foil tape to seal all the joints and connections. My question is, can I apply the foil tape to the inside of the duct? In other words, since this is all new equipment, I have access to the inside of the ductwork. I found it easier to apply the mastic to the inside and outside of the connection, but the foil tape is much easier to apply to the inside. I get smoother seams and the connection is better. My concern is that in the future, if the foil tape fails, will I hear flapping?
Thank you
Thank you
