since the stuff's not as cheap as roofing gunk, we dribble some of the hwmma into the crack along w/CLEAN silica sand to form a block against excess leakage,,, when that cures, we then apply a 2nd coat bringing the level up to grade
i'm changing the originally posted method based on your pics - don't bother w/sealing a 2nd time w/polyurethane sealant,,, IF i were you, i'd pressure wash the slab 1st using 3,500psi, 4gpm, & turbo nozzle - we would
