I added air baffles to each rafter bay and all new insulation last year. I didn't have time to properly air seal around the baffles. They are straight baffles. They do not have the wrap around on the soffit side.
I am planning on installing a continuous vent soffit. Is it ok to use foam board (with spray foam around the edges) to seal around the baffles from below when I am replacing the soffit? Would the foam board be considered exposed in this location? Should I use a different material?
