I see no problems with the install as long as the crawl will remain above freezing. There is a drain to consider to get rid of the condensate the furnace produces. What provisions have you made for that?
what things about the venting have you concerned? I will probably be able to grant you a modicum relief over you anxiety once I have given you the real facts.
Sealed combustion is just about (I would say is) the best system around.
