1 - 6 of 6 Posts
I'm a homeowner planning on installing white aluminum soffits and fascia myself. I saw a YouTube video of a guy using square head stainless steel (I think!) screws to secure his aluminum. Is this a viable alternative to stainless steel nails?
I'll be doing most of the job without an assistant. It seems like using the square head screws and a cordless drill driver would be easier than trying to nail it up.
Any downsides to using screws? Are they driven in to where they just lightly touch the aluminum? Is 1 1/2" long enough?
Thanks. Wow, I would have thought they'd be longer.
Do you use stainless screws for the fascia, since they DO get wet?
Do you put a couple of screws into the face of the fascia at the corner wraparound overlaps?
I regularly use 5/8" screws for soffit. They are labeled as soffit screws at the supplier, they aren't stainless but shouldnt get wet anyway.
I
+1 on the stainless trim nails shot from a pea shooter.
Prepunch the holes with a siding punch as well.
On the screws, 5/8 is plenty long enough, as most soffit is around .019 thick. You can use the pea shooter for the soffit as well, but screws are a bit more user friendly.
· Property Mgt/Maint
good info here guys, anything visible gets pre-drilled (or punched), I do leave my SS nails just shy of flush. (maybe a 1/32) Just enough to 1.) not bend the alum out of shape by indenting, and 2.) keeps the hammer face of the metal.
Never tried the pea shooter but I am sure it would save the fingers starting those small nails.
1 - 6 of 6 Posts
