Hi All,
I built a two-story addition to my house. The addition is attached but mostly independent of the existing house structurally speaking. With one exception...
On the existing first floor, there is a reach-in closet that I made into a walk-in closet by extending it into part of the addition. I had a shell contractor build the foundation and framing, and they are now long gone.
Today I discovered a problem wherein the double jack studs under the header that creates a bigger closet are not bearing on a decent foundation. The first pic shows the headers and jack studs. on the left side the jack studs are resting on the new foundation+sill plate. on the right side, however, the jack studs are resting only only an 85 year-old 2x4. I want them to bear on the existing footer. And I need to remove the 2x4 that is traversing the closet floor.
I figure I can either stack a bunch of PT wood on top of the footer to mate up with the new jack studs, or use a screw jack . Just looking for what is better or other ideas.
I guess my short question is whether a bunch of stacked lumber is sufficient to hold up a very structurally significant jack stud/header?
the first pic shows the header & jack stud situation. the second pic shows that the new jack studs are almost exactly 12 inches higher than the existing footer/stemwall.
Thanks.
Thanks.
