If that box is on the inside of the wall it is compliant. I agree there is more to this picture. Not just water. The sealtight screams DIY!
I assumed he was referring to the fact that this appears to a standard 4-square box with standard steel cover. Not the box or cover to use in a wet environment or one with exposure to whatever chemical did that.How so????????????????????????
It most certainly can. You have no idea how long that has been there. I have seen much worse rusted out boxes than that one.Something other than water did that. Water can't do that kind of damage to steel.
Fitting and plate look fairly new. OP, what caused the damage?It most certainly can. You have no idea how long that has been there. I have seen much worse rusted out boxes than that one.
I understand what you are saying I was only referring to the last couple words that stated "The seal tight screams DIY" I wasn't sure he meant the job itself or just the seal tight cause the seal tight what little bit I could see looked OK and couldn't tell a pro or a DIY did it.I assumed he was referring to the fact that this appears to a standard 4-square box with standard steel cover. Not the box or cover to use in a wet environment or one with exposure to whatever chemical did that.
A liquid tight box and cover, of appropriate material and construction would be needed, i would think. Is this a commercial installation?
If I had to guess I would say the box rusted from the inside out. Water is either coming down inside the conduit or from a fastener holding the box to the wall.Fitting and plate look fairly new. OP, what caused the damage?
I would guess this too.If I had to guess I would say the box rusted from the inside out. Water is either coming down inside the conduit or from a fastener holding the box to the wall.
