1 - 10 of 10 Posts
What grit sandpaper is required for smooth drywall? The walls have been skim coated and need to be sanded. I want to make sure the sanding scratches do not show through when I paint but would like to not waste time with grit that is finer than needed.
Depends on what you mean by "skim coat". Where I am that normally means imperial board coated with a veneer of actual plaster.....and I could hit that with 80 grit and not make a scratch. Not knowing what you have there, start with 220 and if that clogs too much, drop to 150...and if that is clogging and not scratching try 100. Ron
Tileguy
I'm not sure how all the pros do it, but I thought they use sanding screen and not paper. Of course it also come in different "grits".
Jaz
Reactions: joecaption
Sand paper would load up in seconds.
You need sanding cloth, a sanding pad, and a sanding pole.
It comes in fine med. and course.
All are sold in the drywall area at Lowes and Home Depot.
When sanding move it in a cirular motion.
Hi ka24,
Sandpaper works OK - an random orbital sander hooked up to a shop vac is your fastest solution. Drywall sanding screen also works well, again preferably with a vac attachment. For final sanding of joint compound, 120 or 150 does the trick. With 2 coats of primer/paint, and slight scratches left behind will be filled in with the paint solids.
Good luck,
The New Hope Handyman
Property Mgt/Maint
1 - 10 of 10 Posts
