Hello to all,
I've come to the realization that the only tumbled-travertine filler I could find that was spec'ed for outside usage is grout. We have over 1275 sqft of tumbled travertine outside: 500 near the pool as decking, 775 as transition from pool and covered outdoor kitchen. This was installed approx. Nov/14 and it's a CL-based water.
Some of the holes in the travertine are large enough that I want to fill them so dirt, debris and other stays out, bc it darkens w mold and holds water. The polymeric sand that was "tossed-out" by the orig installer looks poor, and it too has become dark, as well as where the pavers butt-up to the foundation.
I am aware of the std rule of grout lines 1/8 or less, use unsanded, esp for tile/stones that could be scratched by the sand in sanded grout. Since many of these holes are much larger than 1/8", here are a few questions:
1. Is there a finer or smaller granule-based sanded grout that has the strength of reg sanded grout, but will look and feel smother in its appearance?
2. I am not going to seal the outside travertine except the coping, but if I do not seal the grout-filled holes, will they turn dark w debris and mold over time? If so, what sealer is recommended to last the longest and work the best? At this point, the cost becomes less an issue bc it's my labor [and knees/back]
that I am trying to minimize regarding more frequent sealings.
The tumbled travertine is a lighter off-white color, so finding a good color should not be a problem. I have some scrap pieces w holes that I'll do first, then see how they look after they fully cure, both w.out and w a sealer if recommended. We live in West Houston so no issue w freezes/expansion.
Thank you very much for your help and advice, it is greatly appreciated.
regards,
tstex
regards,
tstex
