I have a 3-year old, newly built 4,000 sq ft house with 2 Trane HVAC systems - one for each level. Live in Texas, but have both an AC & Furnace. I've been told by several different HVAC companies that I have a very good setup.
No matter what I do, I can't get a consistent temperature in all rooms. Especially when a bedroom door is closed, it can vary +/- 6 degrees from the rest of the house, in winter or summer. To make matters worse, I have a lofted living room that is open to most of the upstairs - so it will often get much hotter upstairs than downstairs - even with 2 systems.
I've had certified techs rebalance the dampers, open/close air vents, but apparently this is just normal. Unless all the doors are open, they say you're never going to get a consistant temp throughout the house. And the upstairs main area temp difference is because of the open-concept loft design.
So I've got two questions:
Thanks!
- Is there anything I can do, without spending a ton of money on zoning, to make a consistent temp across the house?
- For a future house build, is there such a thing as "Zones for Every Room"? Meaning the system opens/closes dampers to make every room the exact same temp?
Thanks!
