1977 built house. Opened up drywall, and it became apparent to me that the structure is sagging. Then knowing this, a sag in the basement also became more visible to my eye.
Do you think this was framed improperly to begin with, or was the design okay and it's just dumb luck?
The diagram shows the 1st floor of a 2 story house (with full basement)
A1-A2 is an internal load bearing wall, that rests on top of the steel beam in basement. Ceiling joists rest on top of the wall.
C1-C2 is an internal load bearing wall, that rests on top of a steel beam in basement. Ceiling joists rest on top of the wall.
D1-D2 is an external wall of the house. Ceiling joists rest on top of the wall.
B1-B2 is a steel beam sandwiched by a pair of 2x10's, and is pushed flush into the ceiling. The ceiling joists attach to beam "B" via hangers
Now get this.... at point "Z", there is a triple stud in the wall. Then beam "B" sits right on top of the point "Z".
I can see that beam "B" has put so much weight on the triple stud at "Z" that "Z" has sunk a good 2 to 3 inches (measured with a level).
Also, it's interesting to know that directly underneath "Z", in the basement, they have triple floor joists. The joists are deflecting the same amount as what's seen on the 1st floor. The joists - seen in the basement - run from "A" to "C".
Is this a 20/20 hindsight poor design, or does this design seem practical to you?
How would you repair this? Would you lift the structure and add a steel column in the basement (with footing), directly under "Z"? Or would you add some sort of beam (perhaps a steel I-beam) in the basement, that spans from "A" to "C", and runs directly under "Z"?
