I want to break up a cement slab, roughly 12'x12' which is raised by I don't know what. When I look under it I see plywood but there is obviously something behind there, whether it's a beam or maybe piers. Either way, it's raised, which makes this a bit more tricky. It's maybe a foot off the ground.
What is the safest way to go about breaking this? Do I start at one end and walk on it and move backwards, or should I move into it and remove debris as I progress through? Also what is the best tool for this, a jackhammer or saw? I'm thinking jackhammer as with the saw there is a risk that it suddenly lets go while I'm operating the saw, with the jack hammer I'm just chipping off chunks at a time.
I'm going to assume there's rebar in there. There is also a large glass patio door nearby, should I protect that somehow? I've never used a jackhammer before so not sure how much debris flies out or if it's just dust. I do need to replace that door... just not now. :laughing:
