1 - 6 of 6 Posts
Hey guys. I have a older ryobi drill charger that when i plug it in it flashes the red and green light indicating "defective" status. it does this both when there is a battery in the charger and when there is not one in the charger.
i have tried attaching the battery while the charger is unplugged and still the same thing.
I was wondering if anyone else has ever had this issue. sorry if im in the wrong forum topic.
just looking for someone who may have had this problem anf found a way to fix it or a link so something i can read up on fixing it. i do have some experience in electronic components so i can take it apart and solder if need be. i cant return it as its about a year old and dont really have the means to go buy a new one right now but need to use the drill.
thanks in advance
Matt
Only time I've seen one do that is with a bad battery.
Use a multi meter and see how many volts it's putting out where the battery contacts are.
It needs to be putting out more then the voltage of the battery.
Most microprocessor controled charges,
need to sense a certain level of voltage from the battery,
To indicate presence of a battery and level of charge.
If for some reason (such as too low a charge or faulty battery)
this voltage is too low, then a faulty indication is given
and charging will not comense !
If battery is not faulty, you need to get some charge in to it
to bring it up to minimum sensing level.
Use a power supply, such as a wall wart.
i understand what you guys are saying but the charger is giving the "defective" lights when there is no battery in it.
both batteries i have tried will power the drill when connected so i know its not due to low charge on the battery.
i think i have bout chalked it up to a bad transitor, resistor, capacitor...component of the charger itself and it needs to just be replaced.
thanks guys for the responses.
MTB
1 - 6 of 6 Posts
