1 - 8 of 8 Posts
I don't see anything like that. There is a Honeywell electronic air cleaner, but that is different. The lower door on the ruud says "filter access door," but when I open it (and the top one in the spec photo) I really can't find anything that seems remotely like a filter.
there is something called a permanent filter n it.
when the pdf is open, do a control then F
then type filter in the search box. you will be searching through the document for the word filter.
Thanks for the information everyone. I am glad I posted the Honeywell info and thanks for asking the questions that got to the answer. The Honeywell it is, so now I have the answer.
I thought I was crazy.
Well, I am, but not for this reason!
You can clean the HW 'filters' or elements with a garden house, if it's not too cold outdoors. Note direction of how each comes out. Otherwise, dishwasher or bathtub (with towels down).
I used a backpack blower (air only) when it was very cold.
If you use water of any kind to clean and elements are not completely dry, you will hear a crackle noise (burning ozone) until dry. This is normal.
Clean after any construction when airborne wallboard compound is sanded.
1 - 8 of 8 Posts
