Unless you can be sure the line under the slab is plastic you’re probably out of luck with this line as it would be rusted underneath the concrete and not safe
Ayuh,..... With what little is left of the system,..... yer startin' at zero,.....Unless you can be sure the line under the slab is plastic you’re probably out of luck with this line as it would be rusted underneath the concrete and not safe
