1 - 14 of 14 Posts
Hello all, just this past winter, located one of my tools after the snow had melted on my lawn. it's one of those small pry bar/nail puller. got most of the rust off using a wire wheel. what type of protectant can I apply to it to prevent it from rusting. Thanks
· Big Dog
I would first thoroughly clean the tool with mineral spirits or lacquer thinner and then apply 2-3 light coats of Rust-Oleum Professional Spray Paint.
The "business" areas of the bar can be coated with a rust inhibitor like Birchwood Casey’s Dri-touch or Boeing’s BoeShield T-9. These dry to form a waxy surface so they are less likely to attract dust unlike lubricants.
COPIED: Phosphoric acid effectively removes the rust because it does not actually dissolve it. It bonds with the rust to create iron III oxide and water.
Apply Phosphoric acid. In about 24 hours wipe it with mineral spirits or a water dampened rag, allow to dry and paint with Rustoleum.
That's what I did with this 1920 garden trowel that was buried in a flower bed for several years but I just never painted it.
I glass bead blast then polish with a wire wheel. Then I put it on a rag and saturate it with WD-40. I rub it in and then wipe off the excess. I have never had one flash rust after that.
· Property Mgt/Maint
My best advice for long term rust protection would be not to store it outside on the lawn. :wink2:
Kidding aside, if you can keep your tools in a room with humidity below RH 50 it will go along way toward rust protection. Higher the humidity, the better rust protection you need.
· Master General ReEngineer
Ayuh,..... I find that regular use is the best anti-rust plan,....... ;)
WD-40 works better than any other product which is not surprising as it was developed by the US Navy and then commercialized. Rust is the result of oxidation so anything that keeps air from a surface will reduce rust. I use carnuba wax on the bed of my table saw and clear spray lacquer on tools.
What also works very well is spray starch and it can be easily washed off with hot water. I use it for tools that will stored away for long periods of time to prevent rust.
1 - 14 of 14 Posts
