I set a j bolt anchor into concrete this afternoon. I mistakenly set it an 1/8" too high for the simpson connectors. I will probably need to grind off 1/8" from the top of the bolt to make them fit. Will this cause an appreciable rust problem where I take off the HDG finish.
Thanks for the replies. I'm using the ABU44 standoff post base. The separate standoff platform won't sit down all the way because the bolts protrude a bit too much from the surface of the concrete.
JOATMON
Oh...ok......yea.....just hack off what you need.
