As you can see in the pictures, my front porch has a crack surrounded by rust running across it. I'm thinking the concrete cracked open and allowed moisture inside which caused the rebar to rust. Someone else had a problem similar to this on another thread.
I have two questions:
1. Is there a really thin epoxy that I can insert into the crack with a syringe?
2. Is there a way to remove any of the rust without damaging the concrete?
Other suggestions are welcome.
We moved here three years ago and it looks the same as it did then. Not ready to tear it out yet.
Thanks for your help!
