1 - 7 of 7 Posts
If when running wires for new construction to maintain the 1 1/4" space yuo obvisously can't staple them next to each other, and the staples can only take 1 cable? Is it good practice to come in through the top of the box for an outlet and when running out to the next, go through the bottom over to the bottom of the next and then out through the top? and continue this around to all outlets? Also any recommendations for box sizes? 2X4 walls? Should I get the largest? except for exterior walls where you may want to get insulation behind?
Master Electrician
I would recommend 22 or 23 cubic inch boxes everywhere. The savings is little for smaller sizes. Depending upon the listing of the staples you use, more than one cable can go uder a staple.
Great thanks. I had 1/2 in staples left over. Do you ever go top to bottom like I mentioned or is it better to get the larger staples, or is it all the same. Lastlydo I have to be concerned wit the bends coming out of the boxes going through the holes to run horizontal? Just fan them out a little?
Master Electrician
You can do it that way but your holes will have to be drilled much lower. Drilling at a little under waist high makes for much easier wire pulling. Whether you go over or below just don't drill too close to the box. Not only wil it be harder to get the cable into the box it will be very difficult to staple them.
So I am better off just drilling above and getting staples that can hold more than one wire. Thant way I can leave space to turn and get down into the box.
retired elect/hvac/plumb
1/2"is all i carry onmy trucks
1 - 7 of 7 Posts
