Here is the situation.
I am in the middle of remodeling a bathroom on the upper floor of a split-foyer. It is right above the unfinished laundry, where the electric box is situated (the lower level is the basement and above the first floor is an unfinished attic). I have taken everything off down to the framing. In the corner of the bathroom there is a roughly 3x4 enclosed passageway that runs straight from the laundry to the attic. In it, the builders ran the main A/C air duct to upper floor, as well as the flue from the Gas Water heater and Furnace.
I had this idea about running 2 conduits from Basement to attic to “future-proof” the place and get ready for future remodel ideas! Conceptually, I would use one to fish electric wires (I was thinking of the usual 14/2 NM-B and 12-2 Romex NM/B which have been ran elsewhere) and the other to run low-voltage wires (RG-6 and Cat 5e. perhaps speaker wire). The purpose of the conduits would have been to simply have a path (it will be about a 9 foot run) between the attic and the basement) to simplify future wiring.
As I look into this, there seems to be more to it than the electrician at the local home improvement store conveyed. I am hoping readers here have better ideas:
1.
What other approach would you use (if not what I trying to do) to accomplish the same purpose? (the rest of the house if finished and I won't get the same straight shot to laundry on any future project)
2. If going the conduit route, I was recommended to use 2 x 1inch PVC 10 foot conduits.
a. Would that be OK for low-voltage wires;
b. I have come across things like fill % (seems to be 40% for 1” pvc pipe) for NM wire in conduit. Apparently, there is danger of overheating. But this would barely give me 2 runs and defeat the purpose of what I had in mind! Ideas?
c. If I run a conduit, what could I do at the two ends for:
i. Fire protection;
ii. Prevent Insects from crawling it;
iii. Preventing heat loss from basement to attic
Thank you
1.
i. Fire protection;
Thank you
