Hey Guys, First post....
I rewired most of my main floor (20 or so circuits) and I'm working on getting them all into the main panel (Bryant with 200 Amp Service)
All the new ones will be Arc fault, but I've only got a neutral bus bar on the right side of the panel. Is it allowed to run the short neutral wires from the circuit breakers across a couple of blank spaces? I read about it somewhere but the source wasn't super reliable.
It's the only way I'll be able to reach with the wires provided. Alternative option of course is to wire nut on some extensions and run them down around the bottom but that will get crowded fast with all of the ground and neutrals running through there.
I've run a couple to see how it would work, see image below.
Open to any other options you pros can think of! Thanks.
-Micah
-Micah
