I'm running a wire from my sub panel in my garage to an outlet in my backyard for a small pool pump and filter. I dug a trench and bought some 3/4" pvc pipe and a box for the gfci outlet and a LB for coming out of the garage. I will use romex wire in the garage from the panel to a junction box on the outside wall and then switch to outdoor wire. It is going to be 12 gauge wire.
My question is what is the best wire to use to run threw the pvc to the outlet? Should I use 12-2 uf outdoor wire or should I use stranded thhn or similar and run 3 individual wires out there? Thanks for your help on this.
