Nope.Can you run Romex through cold air returns?
That's interesting, is there a reason you can only cross it?You can cross through the return as long as it is perpendicular to the long air space.
Code allows it!That's interesting, is there a reason you can only cross it?
No further questions.:laughing:Code allows it!
:thumbup::thumbup::thumbup::thumbup:No further questions.:laughing:
You are required to seal the holes up around the wire penetration with fire stop caulking. Sometimes you have no other route but to cross a cold air return path in a wall.Forgetting the code issue, I never did understand why someone would want to punch holes in their duct. We go through so much trouble to seal up holes and then turn around and punch holes?
Where is that written?theatretch85 said:You are required to seal the holes up around the wire penetration with fire stop caulking. Sometimes you have no other route but to cross a cold air return path in a wall.
