1 - 7 of 7 Posts
EIT/DIY'er
I have about 9 romex wires that I will need to run in one tight area (between two studs).
Two questions:
1) Is it OK for me to stack two wires and fasten them with the same staple to the studs?
2) Are there any products available to run and fasten these in a neat and orderly fashion? It will be a mix of 12 and 14 ga copper romex.
Licensed electrician
Try a 3M Stak-it. Gardner-Bender and Arlington also make the same thing.
Well what I would suggest is nail in an empty staple and zip-tie all the wires to the staple but leave it nice and loose so there not tight around each other that way the heat can dissipate
A "Handy Husband"
An inspector might call you on it.
Reactions: gregzoll
1 - 7 of 7 Posts
