I am installing a sprinkler system and I want to put the controller in the water heater closet inside the house.
Can I then run the low voltage control wires through the floor into the subfloor, where I can run them to the boxes that are next to the house? Would I need conduit for going down the wall, or can I just use plastic staples?
Finally, I want to come through the rim joist under the deck and into the ground. Would I need conduit into the ground? The wire is rated for burial, so wouldn't need it in the ground.
Thanks.
Thanks.
