So I've been researching Pex more because it seems much easier to work with than copper and it's cheaper. A friend has the tool to crimp so I figured I could purchase some tubing and give it a go. The two plumbing projects I need to tackle are moving the washing machine and re-routing the baseboard heater to a new wall. I'm concerned about the baseboard because I don't know how hot the water gets; will Pex work fine for that?
Basically the pipes that go to the baseboard now travel from one corner of the room, all the way around the room to the adjacent corner is started in. Why..I have no idea but it's very inefficient and a waste of pipe. My plan is to remove all of that copper and just re-run it using Pex the correct way. Will Pex work fine for this, are there any potential issues I may run into?
