Howdy! I goofed when I planned my plumbing venting because I was unaware of the UPC aggregate venting rule. I've got a 1.5" vent and a 2" vent coming through the roof, and will need to add another hole or increase the size of one of the vents to meet this code section. Increasing the 1.5" pipe to 2.5" should do it. I'll confirm with my AHJ before I actually do anything. Luckily I figured it out before doing any other work inside!
I'm trying to figure out if I'm better off replacing the boot or trying to widen the hole without removing the boot. Here are the questions I think I should be asking:
First, is it hard to remove a boot and the adhesives/sealants on a metal roof? (picture below of exactly what I have)
Second, is it reasonable to carefully remove the existing pipe, and widen the hole to put larger vent pipe through the existing boot? I'm thinking a multi-tool and go really slow and carefully.
Any thoughts or other options I should be considering?
Cheers!
Cheers!
