Hello,
I just bought an ecobee3 thermostat for my condo that I am renting. It previously had a Venstar T2800 Thermostat.
I have a FHP Bosch EC024- Unit, and I believe it’s a geothermal since there is water connections going in and out and that’s seems to be what I found after doing some research. I know it is a Heat Pump from the settings off of the old thermostat.
The Venstar T2800 has the humidity chip installed and had a wire going to the MISC2 port. There is a jumper on the thermostat that allows you to pick what you have hooked up Hum, DeHum, etc. The jumper is currently on Dehum so I am pretty sure there is a built in dehum into the FHP system. I connected that wire to the misc port on the ecobee and selected dehum.
The issue I am having is any time the fan runs the humidity goes up quickly. If I turn just the fan on when humidity is 52 it will jump up to 70 within 10 to 15 minutes. I have the option to run the fan when the dehumidifier if running and since the fan is running the humidity actually goes up.
Does anyone know why running the fan would cause the humidity to go up that quickly?
I live in South Florida and my condo is on the 16th floor facing north if that helps at all.
