I'm looking to add a new circuit to my garage (it currently has a single outlet, which is a travesty), and happen to have an unused 30 amp double pole 240v circuit to use. I'd like to route that circuit to the garage and use it to run outlets and a few more lights. The issue is that the circuit seems to only have 2 hots and a ground.
I'll obviously need a neutral to make this work. Is it possible to add a neutral to this so I can run 15 amp outlets? Would the neutral need to be tied into the neutral bar in the panel or can tie into an existing neutral in the existing garage wiring? It's a split bus panel so I'm not entirely sure how safe it is to open it up and add wiring since there isn't a main disconnect to shut everything down.
Ideally I'd just tie in off the existing outlet/lights in the garage for the extra devices, but the garage is already tied into my kitchen/hallway/laundry room so I'm not sure adding more to that circuit will get me anywhere.
