Hi, I'm planning out the vent run on a future high efficiency gas furnace. Because of the order of projects I would like to pre-install part of the PVC piping ahead of the furnace install. The furnace manual (Goodman) specifically states not to use rubber couplings but it will be difficult to connect two fixed runs of PVC piping without one.
So i have two quick questions:
1) What is the problem with using a rubber coupling in a high efficiency furnace vent? Will the flue gases eat through the rubber, or is it a structural/rigidity issue?
2) Do high efficiency furnace flue approved couplings exist?
3) Are there any tricks to connecting 2 fixed runs of PVC without a rubber coupling? My issue with it is it's hard to mate the joint the full depth when you're bending and snapping two fixed pipes into a PVC coupling and can't make any adjustments due to the PVC cement curing so fast.
Thanks for any thoughts.
