1 - 2 of 2 Posts
· Hvac Pro
There may be a sticker on the back of one of the doors which tells you what that code means. If you had a power surge the circuit board may be damaged. I have had a LOT of those units with cracked heat exchangers and faulty compression rings which hold the exchanger together. For your own safety I would get it professionally inspected.
1 - 2 of 2 Posts
