Ok.
So I generally know what I am doing with spackle and paint etc..
But I am opening a huge can of worms and I want to get er done.
I have a 1910 colonial with plaster walls and trim that has a billion coats of paint on it. From the looks of it, improper prep work/no sanding/no wiping/ paint over dust etc...
Looks lumpy.
When I try to sand the paint gunks up the paper immediately and unless I have sander set really slow it seems to almost melt and make a bigger mess.:furious:
When I try to scrape I end up chipping alot away and creating a very uneven surface for the new paint.... you can see where the paint was chipped through the primer and top coat. Looks crappy.
The trim is dented in many places and the trim is intricate.
It is 1x6 with a cap of three beads... it looks like the trim to right on this page.
http://www.moorewoodworking.com/historical-molding.html
Furthermore, where the paint starts to chip on its own, I want to stop it. Can I prime and skim with vinyl spackle?
The joints between the moldings... some have small gaps with random paint in it. The door jams are beat up.
So, My question is this...
Will vinyl spackle like from DAP be a good product to smear all over the place and then shape and smooth? How to prep so it lasts?
I know I can make it look smooth with joint compound, but it seems like I might be cursing myself 10 years down the road.
My current plan of action is scuff, skim and fill coat, sand to shape and smooth, prime, paint.
Looks lumpy.
