As part of a project, i took the toilet off in order to paint behind it.
What I noticed was there was rust on the bolts and it appears the wax ring may have leaked some. I pulled the flooring up to find the luan flooring was damp. I ripped one section of the luan up and noticed the plywood subfloor was also wet.
I've checked and the flooring is not soft. I'm not sure if i should cut it out and replace it, or spray with bleach and let it dry. I'm somewhat handy, but have never replaced subflooring before, and would like to avoid it unless it is really necessary.
I've attached photos. Can someone take a look and see if it needs to be replaced?
Thanks!
Subfloor
http://imgur.com/sdaval&f8Pwv
Luan
http://imgur.com/sdava&f8Pwvl
Thanks!
Subfloor
Luan
