I have discovered that about 3 inches of the bottom plate that run next to my patio door is rotted. The water entry issue has been fixed already. The patio door is in a room on a concrete slab, the door frame has 2 jack studs and a king stud. The studs do not have any rot, but the bottom plate under the jack and king studs has rotted. The door frame has not sagged at all, but I want to replace this piece of bottom plate so it does not become an issue.
I am already planning on replacing the door in the spring, but the weather will not be conducive to removing the door for about 2 more months.
Could I support the door frame and just cut out a section of the bottom plate and put a new piece in under the studs with the door in place? Since this on concrete I'm not having to deal with a rotted sub floor or floor joists.
