1 - 9 of 9 Posts
what am I doing wrong? Broke 2 bits in short order rotozipping out doorways.
Is there a way to make this easier? chuck them deeper so dont touch wood so much?
Retired Moderator
Move faster---It's easy to over heat the bit---you will learn---and wreck a few bits on the process.
To fast and they snap---to slow and they get hot--
and sometimes there is no explanation--
100% sure your using the right bit?
Are you cutting in a clock wise direction? (starting on the left, go up, at the top moving from left to right)
Also,
Keep a light pressure on the bit, don't over do it. You have to acquire a feel for the bit against the hard surface you are trying to follow. Set the bit just deep enough for the pilot section of the tip to run on the stud.
Mike Hawkins:)
Discussion Starter #7
bought a 1/4" bit and that seems to help. those 1/8 bits are like small drill bits,,,broken.
Can you chuck them just 1/2 deep plus the bare nose? the less stud shaving you do seems the better. Its not a router after all.:laughing:
That's the whole reason the tip is there, to act as a guide. Set to low the bit's going to over heat and dig into the wood.
1 - 9 of 9 Posts
