Hello all,
I am doing a complete renovation of the downstairs bathroom (thanks to some fun water damage…) and would like to rotate the toilet 90 degrees. After perusing the web for a while, it seems like I am going to run into some code issues for toilet flange location if I turn the toilet.
First of all, the bathroom has a raised subfloor (2x4s on end). Therefore, I have 5” from the slab to the flange (all ABS). Originally, the toilet faced north. From the studs to the center of the flange, there is 15 ½” to the east, 12 ½” to the south, and 30” to the west. The door (on the east wall) barely clears the toilet. I was hoping to point the toilet to the west instead. See the attached rough diagram…
So, here comes the problem. For code, I will need 15” clearance from the center of the flange to the south wall to turn the toilet, but there will only by 12” after drywall (see exclamation point on drawing). I realize I would have an extra 3 inches behind the tank, too, but I think I could make it work.
Is there an offset closet flange that will shift over 3”? I realize the toilet really should drain straight down, but could I cut off the current flange and put in an ABS elbow? Is there another way to accomplish this, or do I just need to deal with where the toilet currently sits?
Thanks in advance for your advice.
