I had my oak hardwood floors refinished with a semi-gloss finish. Sixteen years ago I had them refinished with a satin finish and I don't remember seeing these rotating marks that I am seeing now. Is it true that the rotating marks will show up because of the semi-gloss finish or should that not be the case. Thank you
It sounds like the sander did not do a proper job on the final screening. Those marks should not be visible. They often don't show with a clear finish, but will be very obvious if stained. The only way I know of to get rid of that is rescreen and refinish.
